Passenger window won't work
1 reading
4.6K views 4 replies 2 participants last post by  SquallLHeart
#1 ·
My passenger window will not roll down, and even after resetting the windows and trying to reset the window, it still didn't work. I checked all the interior fuses underneath the steering wheel and all of them checked out ok.
do any of you know what could be the solution to this mystery?
also, the top the 3 LEDs on my hvac that change the mode and front and rear defrost stopped working at the same time. i changed out all of my LED's and resistors except the ones under the LCD and when i plugged it in to check if they all worked and it did. after putting it all back together, those 3 no longer work and my window won't roll down.
I don't know if either of those effect each other, but i figured i'd throw that in there.
