ok so i put a sub and amp in my truck. i have a crossfire 1000d and an audiobahn sub that my brother gave me. its worked fine for a few weeks but today i was listening to music in my truck and i changed the song i was listening to and the sub stopped playing. i took out the sub and checked all the connections and they were fine, i didnt blow up the VC's so i screwed the sub back in and put it in my truck and as soon and the amp kicked on the sub went F'in crazy, hittin the same note over and over so i turned it off and switched the positve and negative wires going into the sub box and turned it back on and it worked fine. so i drove my car up and parked it in our driveway and turned up the music and i got nothin. so i checked the ground and power and all that to make sure and that was all good, so i lifted the box up and checked the connectors and everything was connected, the amp was on and wasnt in protection. i pushed on the negative terminal and the sub started to play and when i let go it stopped. i then pushed on the positive and it did nothing and then i took my finger off the positive and touched the negative and the sub went crazy again and my finger started to tingle. after that i started talkin to a friend and when i came back the sub was playing and it was fine. so i hit the button to change the cd(10 disc cd changer in the back) and i could hear noise in the sub when i changed cd's. it sounded like the cd changer just amplified and in the sub and i changed the cd a few more times and it kept doing it and when i pause the music the sub kinda taps, it doesnt stop playing. its ver low but its annoying, if i turn the bass boost down it stops but it shouldnt be doing that. any idea of whats wrong? im thinking maybe my amp went bad but idk. what do u think?
__________________
__________________
