1 - 2 of 2 Posts
Hey guys, been a while since I've posted here but I have a question:
If i get
Size: 18 x 8
Bolt pattern: 5 x 100
Offset: 35
Would I have to switch the tires as well? Or can I just use the stock Potenzas
and also, what about the "wheel backspace" being 5 5/8" ?
(By the way, these are either Motegi DP12s or Zenetti Mystics, im still debating between the two
18x8 +35mm offset will fit very nicely.
You have to change tires, your stock tires require a 17" diameter wheel, they will not fit on a 18" wheel.
If you have the release series car it comes with 18" but you have not specified by you did mention Potenzas so I take it you have the 17's;)
1 - 2 of 2 Posts
