Window problems after sound system installed.
1178 Views 6 Replies 6 Participants Last post by  SpeeedTc
Hi guys, I'm new here and this is my first post. I have a Scion TC "silver" I think is the best car you can get for the price. My mods are: Trd lowering springs, Ground effect kit, spoiler and my lates upgrade "yesterday" a 12" Xplore dual Coil on a small custom box with 1000 amp. This is all for now.
The other reason I'm writing is because I'mhavinga small problem after I installed the sound system.
I have the Stock Pioneer radio with Ipod connectivity and I connected to it the "Hi/low" RCA output converter. I ran the RCA cables to the back (amp), then I ran the cables from the FL speaker (violet and pink), FR (light green and blue) all the way to the amp, and from the back speakers RL (brown and yellow), RR (red and white) to the amp aswell.
Now the problem I'm having is that I cannot bring up and down the passenger window from the driver side buttons (it does work from the passenger ones, but it won't "auto lock" so it goes up and dowm by itself)
Anybody had this problem before?, could anybody help me?
Thanks
Luis
1 - 7 of 7 Posts
You have to reset the windows. It is in the tsb. It will show you how to do this.. I had the same thing happen to me...
You disconnected the battery?
Hold the pass door window switch up for several seconds (or down if it doesn't work). It will reset and start working normally. Blinking green light on it should have been a good enough hint...
What they said. You'll probably have to reset the sunroof too.
Yeap I did disconnected the battery!!! That is exactly what happened!! Thanks a lot guysit worked perfect!!!
Next time you have something like this you should check out our Information section to see if the asnwer or process is already in there. Glad you got your problem resolved.
Welcome to yoursciontc.com ! Nice to hear you got a tc
1 - 7 of 7 Posts
