Ok just so you know I am only 17 and this is my first car. I read everything and I found that the Bolt Pattern is 5x100, the offset range is 35-48, and that the wheel size range is 16x6.5 to 20x8.
So knowing that I found rims that measured 5x100 - 5x4.5/114.3 for the bolt pattern with a 37 mm offset. I also saw the same rims that measured 5x100 - 5x4.5/114.3 for the bolt pattern with a 45 mm offset.
Will either of these fit the TC? (if so which ones)?
Which is better if they both fit and why?
What is OEM tire size?- I read that somewhere.
What time size would you recommend? I thought 225/40/18 sounded good but i don't really know what I am talking about
Thanks for the help.
