1 - 5 of 5 Posts
What if I ran a 10 or 15 mm spacer? That would make it more like a 38 or 33 offset right? I am not very good with the offset thing. The wheels I want only come in 17X7 in a 48 offset for the 5X100 bolt pattern.
Not a big fan of spacers, they can work but only the really expensive ones, others will give you plenty of vibration which Toyotas are prone to do with aftermarket wheels even some when using hub centric spacers, which we all should use with our non stock wheels.
1 - 5 of 5 Posts
