I got some window decals in the mail from Luminics. I was wanting to know what would be the best way to put these on? Do I clean surface with Rubbing Alcohol?
On my honda I would put them underneath my hood but I would not put them anywhere on the car except there and I only had like 4 anyway, turbonetics, hks, fidanza, and AEM
i have i-club decals....but, yes, spray with windex then put the decal on. i let it set for a little bit then went over it with a credit card to make sure it was all the way down and to not allow bubbles to show.
1. Clean the surface with a paint thinner
2. Lay it out and tape down the top
3. Measure and adjust it so that it's even and straight
4. Fold it up, remove the transfer tape and slowly lie the vinyl down squeegeeing(s/p) as you go
5. Make sure you use the squeegee!
6. Remove the transfer tape... let it set up and re-wax the next day.
just clean the surface well with window cleaner.. then make sure it's straight...press down on the outer paper with something such as a credit card or razor blade (if you feel skilled enought not to cut yourself).. then slowly pull back the paper as you go
good luck it's really not that hard
1 - 12 of 12 Posts
