1 - 5 of 5 Posts
ok.. my sub is starting to burn, just like the one before, and the one before that. It seems to do it with songs with bass in the 60-80 hz range. High range bass. But the really puzzling part is that the other one is perfectly fine. Got 2 amps, 2 speakers, one amp to a speaker. Both amps are digital and all their settings are EXACTLY the same... AND the RCA cables have the same signal. (mono) I have got to know wtf is going on, before i blow another $250 speaker.
Define burn....
It could be something as simple as noisy cables, or that the box isn't sealed correctly. Also a distinct possibility is that the gain is set incorrectly. Any of these things are bad, and combined with eachother could cause woofers to blow over and over. If you are having too much trouble just take the woofer back to the shop where you got it, it should be under warranty.
you mean the RCAs got interference on um? The box is ported and it doesnt have a split between the speakers, its one big box. The gain is exactly the same because the amps digital, its set at -12 dB
Help me audio gurus!!
EDIT: burn = the wonderful smell of burnt electronics, AKA a burnt voice coil. The last speakers would blow a Voice Coil, but the other would ok, just 5 ohms insted of 4 ohm (i measured it lol)
Burn could mean a lot of things, that is why i asked
Well here is my best guess from what you have told me:
Unless your ported box is perfect you need to not run max power to the speakers or they will go beyond their limits easily. Sealed boxes can handle a lot more power than a ported box, especially a boomy bass ported box.
There is no need for the subs not to be in seperate chambers. My best guess is that you are pushing the voice coil beyond the limits of its suspension because
A) there is too much power
B) there is not enough pressure in the box(ie the port or box are too big)
C) A combo of A and B
Edit: Many subwoofers have bump stops, but the voice coil still does have a limit and if the box is forcing the voice coil to hit that limit a lot it will eventually burn up. That is my best guess to what is happening.
Hope this makes sense
Ed
yea that helped. thanks eddie
1 - 5 of 5 Posts
