1 - 1 of 1 Posts
Tube Fabrication manufacturers The great thing about Stainless steel tubing is that it鈥檚 designed to resist high heat and high-pressure conditions. Here are some of the different uses for stainless steel tube forming fabrication. Household application Construction application Automotive application Material Handling application There are a lot of other uses for Stainless steel tube forming fabrication; you can鈥檛 go wrong if its strength, versatility, and durability are what you鈥檙e after. We have been experienced in producing Steel Tube Fabrication parts for almost 20 years. With over 400 workers and a fully equipped and modern machine, including Laser Cutter Plasma Cutter, Automatic multi-bends, robotic bending machines, 44 sets of welding robots, and four powder coating lines at your service, MH Metal can meet your exact Steel Tube Fabrication needs. Please get in touch with us and let us know what we can help you with. Our full-automatic pipe cutting machine The knife edge of the full-automatic pipe cutting machine is flat without any burr. The use of the full-automatic pipe cutting machine solves the operation problems of the old-fashioned cutting machine. The full-automatic pipe cutting machine is convenient for the following process. The structural aspects of our pipe bending Machine 1. The pipe bender adopts a touch screen and numerical control module, with dialogue operation, and the program setting is simple; 2. The bed structure is stable and not easy to deform; 3. Each file can be set with 16 bending angles, and the memory can store 16 groups of files; 4. With a slow positioning function, the bending angle is stable, and the repetition accuracy is 卤 0.1 掳; 5. The error message is displayed on the screen to help the operator eliminate it immediately; 6. Provide self-developed coordinate conversion elbow processing values. The software can be purchased and installed on a desktop computer for editing and calculation.Tube Fabrication manufacturers website:China Custom Tube Fabrication Manufacturers Suppliers - MINGHUI
1 - 1 of 1 Posts
