1 - 20 of 60 Posts
this is VIN specific, but it is a new TSB i got this morning.
5spd tC's with a VIN prior to : JTKDE1#7#50016119
you may experience a loose feeling shift gate, or a rattle from the shift lever. if so, head back down to your dealer for the replacement of your shifter. everyone after that VIN, you got the replacement shifter in your car at the factory.
just giving you all a heads up.
Thanx for the news...I had a loose shifter and took it back to get replaced and now it runs great.
i went to the service dept @ sparks, they said the TSB is still active, and said that my car was coming up as a match, even though my VIN# is higher than the one posted.
so, even if your VIN# is higher than the one in the bulletin, you might want to go ask.
the process involves diagnostics, and then they order the part, so it will most likely be a lengthy process. the only part replaced is the actual shift lever, so i'm gonna have this done before i install the short shifter. that way i'll have the corrected part if/when i return it to stock
Some of us are still waiting to hear. Just what is a loose shifter? How are we to know if we need to take her in?
Thanks!!
I was one of the first people to get a Scion Tc back in July 04. My car qualifies for this TSP...number 5000 something of the assembly line. The car drove fine for a few weeks. My shifter started to feel "loose" when engaged into 1st, and 2nd gear. Usually you only get play on the shifter when it is in neutral but I started to notice that something wasn't right when even in 1st gear it had alot of play. I took it to the dealer after comparing it to other manual cars. The dealer at the time did not even have a manual Tc to compare my problem to but I knew that it didn't feel like the way it felt when I drove it off the lot. To make a long story shorter, the Toyota salesman was kinda of handy and he took apart the shifter cover and realized that the plastic shifter popped out of place when you pushed the shifter too hard to the left. It didn't cause the problem when you push to the right. He pushed the plastic ring back into place and it felt normal again. I thought it solved the problem but the darn thing kept popping back out and feeling loose again. So Toyota had to order a whole new shift assembly and replaced it. The problem seemed easy to solve if they just built the shifter stronger, one screw int he right place would of solved it, but the shifter is all plastic and used a snap together design. The problem here was a simple plastic ring cap that keeps the shifting ball locked in place. It's hard to describe but easy to point out if you ever looked at the plastic shift assembly. My problem had nothing to do with the clutch itself, just the cheap plastic assembly that couldn't even handle the normal force that you would use to engage into 1st gear. If anyone has this problem, it would feel like the shifter is loose when engaged into gear. While in first the shifter should stay close to the left, when my shifter was loose it would drift back to the neutral position. Annoyed the hell out of me because you couldn't tell what gear you were in visually. Since the replacement I've had no problems with the car accept for a slight drift to the right that should be solved with an alignment....which BTW the dealer said they didn't have yet for the Tc. Sounds like BS to me, I don't know how after 5 months they didn't have alignment info available for the Tc...getting off topic, hopes this helps fellow Tc owners.
Need to revive the old thread. Hopefully somebody with better Toyota connections than me can give some advice. I noticed a side-to-side free play in the shifter today when in gear - about 1/4" each way or so (that's with the TWM installed).
So the question is - what was the TSB about / what was the fix and what was the cost of parts. I don't feel comfortable taking this to a dealer, since I did mess with the shifter installing the TWM kit, but since my tC is one of the first ones out there is a good chance that it's some stock part's fault.
Any help appreciated.
Originally posted by Technical Service Bulletin October 15 2004 TC007-04
Some 2005 model year Camry, Corolla, Scion tC and Solara vehicles with manual
transmission may experience one or more of the following conditions:
A loose shift gate feel
A rattle from the shift lever assembly
These conditions may be caused by the shift lever assembly retaining ring lifting (see illustration on next page) and allowing excessive movement of the shift lever. The shift lever assembly has been improved to eliminate this condition.
Production
Change
Information
Scion tC Japan 5 Speed JTKDE1#7#50016119
Repair
Procedure
1. Verify that the condition is caused by the lifting of the shift lever retaining ring.
2. Replace the Shift Lever Assembly following instructions on the Toyota Technical
Information System (TIS), 2005 model year Repair Manual: Manual
Transmission/Transaxle, Floor Shift Lever Assy (Mtm): Replacement.
3. Verify shift lever operation is normal after repair.
Parts
Information
Scion tC part number 33530–21020  Shift Lever Assembly
[.02]
put your stock shifter back in and take it to the dealership for the warranty.
[/.02]
I took it to the dealer with the TWM in, good thing I know the techs and tip them every once in a while, so they remember me. Ordered the new assembly, should be here on Wednesday. They also said they'll move the TWM in the new assembly for me
Oh, and yes, it's going under warranty.
short shift lever making ours shifter look like that:
I wouldn't have done it if the damn thing wasn't wobbling like a twizzler.
1 - 20 of 60 Posts
