Check all the bolts/nuts you touched - retorque them.
Yeh, what he said.Originally posted by inevitablegod@Feb 4 2005, 10:38 AM
its difficult to imagine how it would mate up without being in correctly. i would re-torque everything. also, something i found out on the 4th install - loosen the bushing mounts on the sway bar a little so there can be a bit of play in the bar. then torque your link assembly bolts first, followed by the bushing mounts. seems its hard to get the right torque spec on the link assembly if you dont have the bar aligned 100%.
do you have just the sway bar installed? or have you done shocks and springs?
