1 - 6 of 6 Posts
Can anyone pls tell me w/ the TRD springs is if the tires wear out evenly? Or i need to add camber kit and stuff to fix the off set. I really want the tires to wear out evenly...TY
Add alignment service and you will be fine.
TRD = easy
install
align
done
Originally posted by fmtc06@Nov 4 2005, 12:12 PM
thanks for the info..now i just gotta find a place that alligns and wont mess up any of the rims around here in orange county
You have a lot of good Dealers in OC, if that's the CA OC. If you go to an independent and need the alignment specs they're on our site.
http://www.trdsparks.com/displayparts.php?...11&parts_id=677
Ken
Great stuff. Keep in mind, when you lower the vehicle the numbers are going to be different from what is published here. The first thing they tell you to set is ride height, and that's what is most changed by the spring install.
The key thing to get right is the toe-in on both ends. It is most responsible for tire wear.
1 - 6 of 6 Posts
