1 - 8 of 8 Posts
TORQUE SPECIFICATION
Part Tightened ..... ft-lbf
Spark plug x Cylinder head..... 14
Front wheel ..... 76
Engine hanger No. 1 x Cylinder head ..... 28
Engine hanger No. 2 x Cylinder head ..... 28
Radio setting condenser x Cylinder head ..... 7
Water bypass pipe No. 1 x Cylinder block ..... 80 in lbf
Drive shaft bearing bracket x Cylinder block ..... 47
Drive shaft bearing bracket x Stiffening crankcase..... 47
Engine mounting insulator RR x Engine mounting bracket..... 64
Engine mounting insulator FR x Engine mounting bracket FR ..... 38
Engine mounting insulator LH x Engine mounting bracket LH ..... 64
Engine mounting insulator RH x Timing chain cover ..... 38
Engine mounting member x Body ..... 33
Battery carrier x Body ..... 9
Air cleaner case x Body ..... 44 in.lbf
Balanceshaft housing x Stiffening crankcase ..... 1st step 16ft.lbf 2nd turn 90 degrees
Stiffening crankcase x Cylinder block 24
w/ head taper screw plug No. 1 x Cylinder block..... 19
Oil control valve filter x Cylinder block ..... 22
Cylinder block water drain #### x Stiffening crankcase assy ..... 18
Cylinder head x Cylinder block ..... 1st step 58ft.lbf 2nd turn 90 degrees
Camshaft timing oil control valve x Cylinder head..... 80 in.lbf
Camshaft timing gear x Camshaft..... 40
Camshaft timing gear or sprocket x No. 2 Camshaft ..... 40
Camshaft bearing cap No. 1 x Cylinder head ..... 22
Camshaft bearing cap No. 2 x Cylinder head ..... 22
Camshaft bearing cap No. 3 x Cylinder head ..... 80 in.lbf
Oil pump x Stiffening crankcase ..... 14
Chain tensioner plate x Stiffening crankcase ..... 9
Oil pump drive shaft gear x Oil pump ..... 22
Chain vibration damper No. 1 x Cylinder head ..... 80 in.lbf
Chain vibration damper No. 1 x Cylinder block ..... 80 in.lbf
Chain tensioner slipper x Cylinder block ..... 14
Timing chain guide x Crankshaft bearing cap No. 1 ..... 80 in.lbf
Chain tensioner assy No. 1 x Timing chain cover ..... 80 in.lbf
Crankshaft pulley x Crankshaft ..... 133
Oil pan x Stiffening crankcase ..... 80 in.lbf
Oil pan drain plug x Oil pan ..... 30
Water pump assy x Cylinder block ..... 80 in.lbf
Water pump pulley x Water pump assy ..... 19
Crankshaft position sensor x Timing chain cover..... 80 in.lbf
Camshaft position sensor x Cylinder head ..... 80 in.lbf
Oil filter union x Stiffening crankcase ..... 22
Oil filter x Oil filter union ..... 10
Ventilation valve x Cylinder head cover ..... 14
ribbed belt tensioner x Timing chain cover ..... 44
Engine mounting insulator RH x Body ..... 38
Vane pump oil reservoir bracket x Body ..... 69 in. lbf
Return tube x Body ..... 69 in. lbf
Radiator reserve tank assy x Body ..... 44 in.lbf
Engine cover No. 1 x Cylinder head cover ..... 62 in. lbf
Exhaust manifold converter x Cylinder head ..... 27
Exhaust manifold heat insulator No. 1 x Exhaust manifold converter ..... 9 ft.lbf
Manifold stay No. 2 x Exhaust manifold converter ..... 32
Manifold stay No. 2 x Stiffening crankcase ..... 32
Manifold stay x Exhaust manifold converter ..... 32
Manifold stay x Stiffening crankcase ..... 32
Oil level gage guide x Water by−pass pipe No. 1 ..... 80 in.lbf
Drive plate & ring gear (A/T) x Crankshaft ..... 72
Flywheel sub−assy (M/T) x Crankshaft..... 96
Connecting rod cap x Connecting rod ..... 1st step 18ft.lbf 2nd Turn 90 degrees
Crankshaft bearing cap x Cylinder block ...... 1st step 15ft.lbf 2nd 30ft.lbf 3rd turn 90 degrees
1 - 8 of 8 Posts
