Congrats, jack.
don’t fret about your age, I’m ten years behind you and landed a 2012 tC.
check out my bio.
check out my bio.
I'm a Chevy man myself. My first car that I bought in my senior year was a '67 327, Chevy Camaro. Had a 2 speed powerglide that I changed to 4 speed Muncice M21, Holly 650, Edelbrock Hi-rise. Loved the G-force. Unfortunately, due to hard times had to sell it around 2012. Yeah the Scion is great fun, though I no longer go radical for all out power. The age thing is a fact that I have to contend with that I no longer have the strength to bench press the tranny into connecting the engine. The Scion tranny install in the connection to the engine have 3 obstacles in lining up, the rear motor mount, the pilot shaft, and the bolt holes. The trans/axle does not have a flat bottom for a floor jack which makes lining up very difficult. Yesterday I spent 3 hours with no success, today I'm psyching myself up to tackle it again... I'm determined and confident I'll be able to do it. I have pixs on part of my process that I'll share later.Congrats, jack.
check out my bio.
Whining noise in all gears, sounds like trans/axel (rear end gear box in our rear wheel drive) or CV joints (any detoriated rubber boots). I would check gear oil if it is to level, or drain and refill... see if there are any metal particles in the drain.Chevy man here too! Impalas, Novas, Monte Carlo, Camaros. I had a 69 Vet, 327 Muncie rock crusher four speed.
I’m going to have my Scion manual trans diagnosed because of a bad whine noise in every gear. After a full clutch replacement it’s still noisy. I suspect it is the spline shaft from the trans into the clutch throw out bearing.
You did a clutch job already... did you change the throw out bearing? If you step down on the clutch and you hear noise when you do, it's more than likely the throw out bearing. Definitely throw out bearing if you don't hear the sound when the clutch is released. Common practice is to always change the throw out bearing with every clutch job.I know it’s the transmission because while the car is rolling and you pushed in the clutch, the sound speeds up or slow down depending on the high or low gear I’m in.
