Has anyone looked at the specs for the tC?
for manual the sway bar is 21mm front and 18 mm rear
the automatic sway bar is 21mm front and 20 mm rear.. even though it weighs 5lbs less in the rear than the manual..
the differences in front weight is about 70lbs.. which would account for the auto tranny.. but physics tells you (correct me if i'm wrong) that more weight on the front axles would require an increase in the diameter of that sway bar (Front)..
but the rear weighs 5lbs less in the auto and has a larger sway bar?
someone explain this one to me.. because for me it's telling me the auto would handle better..
