Originally posted by lo bux racer@Sep 14 2005, 11:03 PM
I've driven a lot of different clutches in a lot of different vehicles. The tC isn't difficult or tricky. I was right at home with it right away. However, there is a driver break-in period for any clutch, and in that regard the tC is no different. You have to get familiar with what yours is doing before you can be smooth.
okay, I don't mean to ramble, but I've had the car for a year now and while I've gotten used to the way the car drives, I'm still not too happy with the shifting. I think this problem is most directly related to the drive by wire and potentiometer(?) on the accelerator.
EG. If you apply a slight amount of pressure to the gas pedal you get no response. And if you blip the pedal, your tachometer hesitates before the rpms climb.
I've noticed that while I'm driving occasionally I shift, I feel like I'm applying pressure to the gas pedal, but I look at the tach and its still falling!!! I start to try to slowly apply pressure but the rpms still don't rise. I finally have to really step on the gas to the the rpms up high enough and basically jump into gear. One way I've found to counteract this is to match revs to the cars speed by blipping the throttle up to about 3000 (depending what gear I'm in) then letting out the clutch. But I know this causes excess wear on the engine/tranny/clutch.
It just seems like the pedal isn't responding to slight pressure--its so hard to slowly open the throttle in this car! In first, I can either launch the car, tires spinning, or I can slowly bounce the car forward till I hit 2nd. Its nearly impossible get going smoothly.
