1 - 7 of 7 Posts
Got a problem with the system in my car. I got the system installed by a reputable audio store here in Orlando. The sub is a Kicker Solo-Baric S12L5, the box is a ported box, and the amp is an older Pioneer GM-X862. Problem is, if I'm running the music at a good thump (about level 50 on "Feel" mode), after about 5 min, the sub starts to cut out.... takes a few minutes and then comes back on. I just want to figure out what the problem is. The amp is an older amp my friend gave to me, so I was thinking it might just be too old. The amp puts out 380 RMS, but the guys at the shop installed 8 gauge wires, I guess that handle up to 300w? So I'm not sure if its because the amp is just old, or if I need 4 gauge wiring because its not getting enough power, or if its something misc like bad ground. If anyone has any suggestions it would be appreciated.
Here are some possiablities:
Your amp is over heating and cutting off to go into safe mode, this is what it sound like is happening, its cuttong back on when it cools down. Try taking your settings off "feel" mode. I have mine on Hear and it thumps pretty hard (I also have a bigger system) Turn your gains down a little too. You might be pulling more than the amp can handle.
8 gauge wire should be big enough for 300 watts. Feel your wire if its getting extreamly hot upgrade to 4 gauge. 4 is the standard really. I run 0 in mine.
Just make sure you have enough air reaching that amp. Amps can create a lot of heat.
Cheers!
~Michael
yeah definitely agree its ur amp overheating
My first thought was also thermal. When it cuts out, go put your hand near it... not on it. If it is indeed thermal overload, you'll know.
Where is the amp mounted? Where is it grounded? Should be easy enough to troubleshoot.
Thanks, yeah i checked, the amp is really hot and so are the wires. I'm planning on buying a better amp in the next few days anyways and getting the 4 gauge wire. The amp is mounted on the back of the sub box and its grounded to the metal part that connects the seat to the chassis.
Yeah make sure you replace that wire quick if it melts its a b*tch to clean up plus it can catch your ride on fire. Try getting like an HK800D amp or HK2000D amp if the subwoofers can handle it.
· Premium Member
That's crazy.... I have the same amp pushing a 15" Rockford Punch on 8ga wires... maybe you should turn the gain down just a bit, leave the stereo settings on xA - Hear, with the volume no more than 40-45. This is where I have my settings with no problems.... that's why I am getting another gm-x862 amp for my system I am putting together
1 - 7 of 7 Posts
