1 - 12 of 12 Posts
Ok so I used to have a beetle before I got my Tc and gave the beetle to my mom who should have had the damn thing to begin with. So heres my problem, I boutght rims for the beetle a while back, and now I would like to put them on my TC, but when I went to swap them the freakin bolts didnt line up, I thought it would fit because they were both 5 lug. I was sooo pissed, This whole time I have been tryin to find the time to do this and I finally do and I cant even put those rims onto my car, damnit!
yep... we run 5x100, not 4x100.
he should have bought an xb
If bye 4x100 you mean the 4 lug, well then your wrong. if you could tell by my original post I stated that they were both 5 lug however for sum reason it is different offsets or watever.
Discussion Starter · #8 ·
its possible see that is my problem i just figured that since they were 5 lug that they would fit but boy was i wrong, ohh soo wrong!!!
but i just went on wheelmax.com just to check. And when i clicked my beetle it says to use 5x100, and then i clicked the tc, and it was the same rim and it was 5x100, someone please explain this to me.
Hmm...Tirerack says the same thing. Anyone know why 5x100s might fit one car but not another?
Unless the tires are too big, or something...
· Former '05er
Only the hub bore could cause this problem if they are both 5 x 100 PCD. I'd be surprised if VW's hub bore is smaller than Toyco's. Toyco uses a tiny hub bore.
1 - 12 of 12 Posts
