This is for anyone that says they like their stock tires
who's a douche?Originally posted by greg091@Jul 24 2005, 11:54 PM
douche
It's entirely meaningless because there is no standard tire for the industry. Bridgestone's 160 might be Pirelli's 300. There is no uniform standard for wear rating across manufacturers. The wear rating is only relative to the same manufacturer's tires.Originally posted by EddieMoney@Jul 22 2005, 11:40 AM
400 tread life is better than 160.....by a lot because the scale is 100-500
i've just had to rotate them every 2000-3000 miles, they wear differently than the re92's.. so you can't go 5000.. yea i've had the alignment checked, it's the tires.. gotta rotate them more often..[/b]
Originally posted by TeK@Jul 25 2005, 11:27 AM
QUOTE
How do you find those Avon Tech M550s? I'm getting a set put on my car later today. My car came with the Yokohamas though...Originally posted by f1jay@Jul 24 2005, 06:05 PM
Then consider that the Pirellis' are 50 bucks less per tire which translates to 200 less a set for much better tires. I personally went with the Avons for under 100 a tire w/a 360 treadwear but you can't go wrong with the P-Zero Neros. It's too bad that Scion decided to go with the RE-92's for 17 but to got with the P-Zero Neros for the 18 inch wheel & tire package. Weak
