For those of you wanting a little more from your tC's audio system, you may have had some trouble finding some of the parts required to upgrade your system at an affordable price. I have had some requests for these hard to find tC audio items and have made them readily available to YSTC members:
Front Speaker Kits are a 1" spacer ring to fit a 6-1/2" speaker for $30/pr
Rear Speaker Kits are a 1/2" spacer ring to fit either a 5-1/4" or 6-1/2" speaker (please specify size at time of order) and allow room for most tweeters to fit flush with no bulging of the panel for $25/pr
All spacer plates are built from MDF (Medium Density Fiberboard). They are hand routered and assembled, painted black and pre-drilled for the OEM mounting location. They will not resonate or vibrate like the cheap plastic kits do. Very clean look and a perfect fit!
Add-n-Amp Harnesses ON SALE, now just $40 Shipped!!!
Add-N-Amp Harnesses will plug into your stock radio, giving you an RCA preout and an amp turn on lead to run a sub amp from your stock tC deck. Will also work with most late model Toyota vehicles. This is similar to the harness that is available at eBay, but at a more reasonable price, just $40/ea
Buy all 3 and save $5!!! Just $90 for the complete set!
All items will be built-to-order, please allow up to 1 week to ship.
All prices INCLUDE USPS First Class or Parcel Post with Delivery Confirmation
PayPal your orders to:
[email protected]
Please include qty, front or rear description, size for rear speaker plates, your YSTC member name and mailing address with your order.
Front Spacer Top View
Front Spacer Side View
Front Spacer Pair
Rear Spacer Top View
Rear Spacer Side View
Rear Spacer Pair
NEW!!! Harness Pics!!!
There are two versions of the Add-N-Amp harness. One uses the power/front speaker main harness with the amp turn on lead pre-wired. The other uses the rear speaker harness and adds a wire to insert into the factory main harness for your amp turn on lead. There is essentially no difference in sound quality between the two harnesses. They will both perform equally as well. You may specify which harness you would like, but I cannot guaranty that I can fulfill your request. The following pictures will describe both harnesses.
NOTE: Actual product may vary slightly from the following photos depending on parts availability and procurement.
Power/Front Speaker Main Harness, Amp Turn On Lead Pre-wired (NEW Fixed-Level LOC)
Rear Speaker Harness w/ Amp Turn On Lead To Connect To Factory Main Harness
Factory Main Harness w/ Empty Pin (Amp Remote Output)
Insert Pre-crimped Wire From Add-N-Amp Harness Snaps Into Factory Main Harness
NOTE: Wire Can Only Be Inserted One Way...DO NOT FORCE!!!
If It Doesn't Fit, Try Turning It Around.
Amp Turn On Wire Properly Inserted Into Factory Main Harness.
I currently have only rear harnesses ready to ship. Front harnesses will not be available until the rears are sold out and parts are reordered so please do not specify front harnesses unless you are willing to wait about two to three weeks to fulfill your order.
Any questions, please email or PM me
Thanx,
Greg
[email protected]
Front Spacer Pair
Rear Spacer Pair
Thanx,
Greg
