Speaker Sizes and Stereo Output
13470 Views 17 Replies 6 Participants Last post by  Alpman
Before anyone says anything, I have looked in the forums for this information but I cant seem to locate it.
What are the components sizes? 6 1/2?
What is the peak watts and rms watts of the factory deck?
Is it possible to run an aftermarket sub to the factory deck?
Im trying to see if I can get new speakers and run the factory deck okay.
1 - 18 of 18 Posts
20 views and 0 replies.
Are that many people really as clueless about this as myself?
since that other post that i left some comments on..
found out that the speakers are
2 tweeters 20W Rms 50W peak (by inside door handle)
2 6.5" polypropylene woofers (front door) 20W Rms 50 W peak
2 5.75" paper rear speakers 20W Rms 50W peak
so going off of the speakers RMS 20 X 6= 120 watts RMS.. radio says it's a 160W.. so I haven't been able to clear that up yet.. but this info is probably more than you had
Thanks Mich. That did indeed help.
The factory radio is 160 watts peak power, which ends up at about 64 watts RMS true useable power.
Both the front and rear speakers can be replaced with 6 1/2 in components. But you will have to build a plate to mount them onto. The factory speakers have an oversized triangle shaped mount and you will have to replicate that shape to mount the aftermatket speakers. I used two pair of Alpine SPS-171A ($200/pair) component speakers in my tC. They sound much better that the stockers but you should run a four channel amp to them because they are not as efficient as the factory ones. I would suggest an Alpine MRP-F240 [160 watt RMS, 320 watt peak] ($200) for the four corners. This amp has speaker level inputs, so you won't have to buy any special adapters to hook it up. Turn on the built in x-over to high-pass.
The front tweeter can utilize the factory tweeter bracket to reatin the proper mounting angles. Simply remove the factory tweeter from the bracket, cut off the two tabs that retain the factory tweeter in place and drill a hole dead center of the bracket. Line the Alpine tweeter up with the hole and insert mounting screw from the back side of the bracket to secure the tweeter. Done!
The rear speakers will take a little bit of creativity to mount the tweeters. I used a grill from the Alpine SPS-170A coax speakers and mounted the tweeter coaxially to the grill. If you don't want to go to the trouble of installing components in the rear, use the Alpine SPS-170A coax speakers ($100/pr). They'll work just fine for the rears.
I took pics w/ my camera phone but don't have the ability to upload pics to my puter yet. I'll post pics when I can.
I would also suggest to install Dynamat in the doors and rear side panels while you have it all torn apart. This will make a big improvement to the sound quality of the system as well as reduce road noise.
You can add a sub amp to the stock deck as well. I suggest pairing up an Alpine MRP-M350 [350 watt RMS, 700 watt peak] ($200) amp and an Alpine SBR-122CR 12" ($350) preloaded sub box. This combo rocks!! And the amp can be daisy chained from the MRP-F240's non-fading pre-out. Turn on the built-in x-over and bass boost on this amp too.
Mount one amp under each seat, don't mount them to the box. That just makes it easier for a thief to take the whole system.
If you buy both the male (radio side) and female (vehicle side) wiring harnesses, you will be able to make all connections to the amps and speakers without cutting the factory harness.
Connect the male harness speaker wires to the speaker level inputs of the MRP-F240. The male harness will also include an extra wire which will be used as the amp turn-on lead (radio has this ability, but is not used in the factory harness). Connect this wire to both amp turn-on inputs to eliminate amp turn-on pops.
Connect the female harness speaker wires to the speaker outputs of the MRP-F240.
You should also run a 4 awg power wire with a 60 amp fuse from the battery to an 8 awg distribution block for power. The fuse should be no more than 18 inches from the battery. You should also use a 4 awg cable from your battery ground terminal to chassis ground. The factory chassis ground wire is NOT sufficient for the current that the amps will draw. Ground wires on both amps should be 8 awg. Factory battery and alternator will be sufficient and you should not have to upgrade them.
This 1000+ watt system will pound. You'll be impressed, especially for the money!
These are my suggestions for "upgrading" the factory system. Considering everything else you've already done, the stock deck would be the weakest link. If you took it a step further and replaced the radio, I would suggest the Alpine CDA-9833 ($450). Using this radio would allow you to eliminate the four channel amp because it has a 104 watt RMS (240 watt peak) V-Drive amplifier built in it, saving the $200 cost of the MRP-F240 amp (although keeping the amp would be OK too). The radio features a motorized faceplate that plays both MP3 and Windows Media files. It also has Quick Search to navigate easily through your compressed media files, Media Xpander to restore the sound quality of your compressed media files, built in x-over, time correction, parametric EQ, three lines of text display, three pre-outs, XM and SIRIUS ready, I-Pod ready just to name a few of the features.
Check out all of the specs on these products at:
www.alpine-usa.com
Hope this helps with your questions. Sorry it was sooo long winded, but I wanted to be thorough.
Alpman, thorough is the best way to describe your post.
I have saved your post as a word file, I plan on following it very close. Thanks so much for the time you put into your response. It is truly helpful.
Thanks for all the info, Alpman. I can tell that you like Alpine products.
I hadn't realized that the back speakers were paper-cone...I may actually bother to replace them now. So is a special bracket required for those as well, or just the front? If so, would it be something that a decent stereo installer (i.e., a professional, not me) would be able to take care of on the fly, or would I need to purchase something ahead of time?
Thanks for the helpful advice!
Yes, the rears have the oversized triangle shaped mount as well and the fronts are riveted in. You'll have to drill out the rivets and use 10mm nuts and bolts to attach the new mounting ring. I don't think there is a speaker kit available for them yet. I made my speaker mounts out of 1/4" MDF and a spacer ring on top of that made of 3/4" MDF, stapled and glued the two together and painted w/ Krylon to protect from the elements. You could use ABS plastic as well. Any halfway competent installer should be able to handle this job with ease, just stay away from the big chain stores. You don't want some kid fresh outta HS making a guinnea pig outta your new tC. Just my $0.02!
Duly noted...the particular Hifi Buys I went to last week seemed to know what they were doing.
HFB should do just fine. No minimum wage installers there. Just stay away from the BB's of the world.
Cool, thanks again for all the info.
NP...Glad to help!
Alpman... Did you install the Alpine CDA-9833 in your car? You weren't clear as to whether you did that or not. If you did, what did you do with the extra space?
No, I used the IVA-D300 motorized touch screen monitor. The kit I used was for the xA/xB but had to modify the mounting method. The extra space was taken up by the pocket in the kit.
Hope this helps.
Yeah, check in the member pics. I got a few shots of the HU in there.
1 - 18 of 18 Posts
