I own a 2008 tC with right at 160K miles. I bought it at 107K miles and it has been burning oil ever since I bought it. The way I understand the piston ring problem is that if you keep oil in it, then there shouldn’t be too much of an issue. The car has only had one previous owner, and, to my knowledge, they did not get the piston rings fixed.
I have noticed recently that I will momentarily smell gas while driving over 60 mph. This happens as well at 70 mph but with a stronger smell and a rough idle after coming to a stop. I turn it off and start it back up, and that usually stops the rough idle. I try to baby the engine but on the rare occasion that I accelerate hard, I will notice whitish smoke out of the tailpipe. Coolant isn’t mixing with the oil, and there are no p codes.
I am unsure if this has to do with the spark plugs since when I changed those, I didn’t gap them given the iridium tips. I recently changed the PCV valve to see if this helped the gas smell, and that hasn’t solved the issue. I am unsure if it is the ignition coils or something with the evap system or if it is ultimately the piston rings. I do not think that the cat is at the point to be changed.
Can anybody help me figure out the reason for the smell, rough idle, and smoke?
