They're OK. Not terribly accurate by absolute numbers, but great for measuring changes. They can also be moderately useful when using the same instrument on a number of different cars. The real problem is they are not calibrated to a traceable standard (like a NIST standard), so their absolute numbers could be off more than you would expect.
Skidpad numbers are subject to a lot of variables too. The diameter of the circle, the coefficient of friction of the road, road temperature, tire temperature, who's driving, etc, etc. The only way they mean a lot is when you can either correct for conditions or you can test in the same venue with the same conditions after you've made a change.
A .91 is perfectly believable for a basically stock car with upgraded tires.
