The side view mirror was broken off by a hit and run. The plastic that the three screws screw into broke. I bought one inch long bolts from Home Depot and screwed it back on. (total cost less than $2). The only problem I have now is the turn signal/hazard light bulbs in the mirror do not work. The mirror still can be moved remotely and I could not find any separate fuse for just the right side, so it must be the bulbs. Before I attempt to replace and possibly break the assembly, is there anyone that knows how to replace them?
Thank you for the help.
Jim
Jim
