1 - 4 of 4 Posts
So I have a 06 tC. On the way to work today I lost the ability to shift into 3rd and 4th gear. Gears 1, 2, and 5 are easy to get to but it won’t go into 3 or 4 gear.
So does the gear shift move into the 3 and 4 positions but there is no power transfer or it it that the gear shift will not move into either of those positions? Any strange noises now or prior to it happening?
Go’s in but get pushed back out of gear; won’t engage at all. I put it in gear but it grinds and kicks it out of gear.
Maybe it isn't engaging all the way. Does the shift lever seem to move the same amount forward/backward as it does when shifting into 1st or 2nd? Check the shifter cables to be sure they are both attached correctly (Make sure one of them didn't come loose)
1 - 4 of 4 Posts
