1 - 3 of 3 Posts
Hi all I'm buying a 06 tc and its engine is seized what could have made it do it the current owner says he went to start it and it wouldn't budge. Any help is greatly appreciated
Where is Donnie?
first guess would be lack of oil/enough oil. Does it crank at all? Could be starter/battery if it won't even crank.
Destroyer of Cones
Put it in neutral and put a breaker bar and socket on the crank pulley bolt. If you can move it normally it is not seized. If you can't move it, you may want to pop off the serpentine belt to make sure its not an accessory causing it.
1 - 3 of 3 Posts
