Either, got a speeding ticket and wants to claim mechanical defect, or is trying to beat the speed limiter.
In both cases, pointless. The TC has a 4 wheel speed pickup (how the tire pressure warning works) so, if you manage to mess one of them up, it will take the info from the 3 working ones that check, and tell you that you've got a flat.
The TC redlines at max speed i believe in a stick, and you wouldn't want to go much faster anyways, so that also is kinda pointless.
You could install diffrent sized tires, but that prob. more expensive than the reason you would want to do this. smaller tires make it read fast, and if it is to claim mech. on a speeding tix, and it's because of diffrent sized tires you put on, guess what, still your fault.
There is no mecahnical cable anymore... hense the "sweep" digital needle with high low pots. maybe if you could get into the programing of the cluster, you could change the pot scale, or some other settings. you enter the program mode but taking the positive cable off the starter, not the battery while leaving the negative on the battery, take the cover off the ecu box, and run a jumper from the ecu to pos. cable, then turn ingition on to start. You should see sparks/ flashing lights and you know you did it right. ***( disclaimer- kidding if you do this, you deserve what happenes)_****
disclaimer added^^
