The rpms were moving around 50-100 or so rpm and I could hear "not smoothness" and feel the minor vibrations. ( it was bouncing between 550 and maybe 650)
Car is still running out great but is that normal?
Its got 300 miles on it
Yeah, the A/C puts a load on it. I've noticed it really turns down the performance on a hot day. On the plus side, as it gets cooler, I dial in more heat when using the A/C (usually when it is raining and I need clear windows), and the car gets back to where it should be. A/C on full and small engines are a bad mix!Originally posted by ufgatorfan@Oct 9 2004, 05:17 AM
My car also idles weird when the A/C is on. Clutch out, in neutral----just a very uneven idle. Definitely I bit disheartnening, but I think its probably normal.
I suppose that would vary with how you drive. If you really want to know....Originally posted by phungy@Oct 10 2004, 07:08 PM
how much does the A/C effect gas mileage?
