I'm pretty sure that I want to install my amp under the passenger seat. It seems to me that the easiest way for this to be achieved would be to remove the entire seat while I install it. However, I have the side impact airbags installed, and in the instruction manual it shows that there is actually an airbag inside the seat (it explodes towards the door), unless I was seeing something funky.
If that's the case, how can I remove the seat? I see what screws have to come off, but, what happens if I unplug these two white and yellow plugs that go into the seat?
Also, in that section of that owner's manual, it says to "Contact your Scion dealer before disconnecting the battery"... why?
Second question (easy), I got enough wire to have my ground anywhere I want- where's the best place? The negative battery terminal?
Thanks!!!
Thanks!!!
