1 - 3 of 3 Posts
I highly doubt it would make any noticeable difference.
Not possible to give more than a general comment on this, far to many variables buddy:)
1) Where in the trunk? There is not place to fit it unless you remove the spare tire and then it is a bit tall, stock one at least.
2) what else have you done for handling, better tires, at least a rear sway?
It is a great idea but of itself not that significant if you do not do other things as well.
And, you have to seal it and vent it to the exterior for safety unless it is an Odyssey, Stinger, Optima, etc. Even then not a bad idea but not required. OK, you can possibly use a stockbattery back there, I would have to look into it a bit to make sure though.
By the way, I did that for the first time in 1974:) Did it on my Matrix, trying to fit it in on the tC as well;)
1 - 3 of 3 Posts
