1 - 2 of 2 Posts
I have a few questions about removing the rear section of the exhaust.......
1. How do you remove/take apart/losen (watever) the little hanger things that hold it up?
2. What is the spring thing for that is on the bolts that connect the rear section to the rest of the exhaust? and do those bolts just unscrew like any normal bolt?
i should be getting my injen exhaust in in a few days and just want to make sure i have everything covered to install it myself.
thanks
1: the mounts are just hoks that go through rubber hangers, usually a bitch, there just a matter of gettin the hook through the rubber hanger. a trick is to use a long screwdriver as a lever to pull the rubber mount toward the hook for some slack
2 as for the spring bolts, they unscrew like normal bolts, they are there so the motor can flex (if u dont know what i mean open ur hood and rev the engine while looking at it, it rocks back and forth)
good luck witht the install, if ur jacking the car up USE JACKSTANDS!
1 - 2 of 2 Posts
