1 - 11 of 11 Posts
hi peoples this is my first post and i have had my tC for about 2 months now.
its black with just the standard options and no mods as of yet. i just want to ask a question about lowering. if i put the trd springs on, do i need to install a camber kit? if not, is there a chance of inner tire wear? if anyone reading this has the trd springs on thier car, how is the ride and is there any problems? i just want to be sure about it before i go spend my money. thanks guys.
I can just about guarantee that everyone here that does have the TRD springs would tell you to do it, and do it yesterday. As a driver who likes to feel the road, the springs are a must-have. The suspension is tighter, turning is more responsive, and the car simply looks better with them installed. I haven't heard of anyone needing to install a camber kit, and the likelihood of excessive inner tire wear is pretty slim.
Feel confident in getting the springs. They are the best mod I've made to the car.
thanks guys i am new to all this modification of cars so im gonna need a lot of help about doing it. im gonna make sure i order those springs and possibly the shocks and sway bar. thanks again!
Originally posted by Labfish@Nov 27 2004, 07:29 PM
The sway bar is also a good choice for da money. I'll let you know about the springs...whenever ups decides to find my house.
Same here man and since we both live in Kansas like I see in your picture out cars will become somewhat pf a snomobile....
What part of Kansas are you in?
· Former '05er
Anyone selling a camber kit is ripping you off. Camber is adjustable from the factory by replacing a single bolt. They knew people were going to slam the cars, so they made the suspension adjustable.
Another thing about alignment. Camber less than -2.5 degrees does not cause inner edge wear, improper toe does. Excessive toe in or toe out will eat the inside (or outside) edges of your tires in a few thousand miles. If your camber is in excess of 2.5 degrees, you need to get it back into the realm of streetable (~-1.5) before doing anything else with alignment.
Pics will be up shortly in the member section...sorry for the delay but it's been busy.
Goldenchild - I'm in Olathe. Flippy is in Pittsburg. Good to see someone else somewhat close by.
· Ironhead
yeah, what he said.
and i should know. cause my yoko's are feathering since i neglected to have the toe adjusted after i dropped it. started noticing that tell-tale sound about 4000 miles after the drop. by then, it was too late. new tires for me in the summer.
· Former '05er
Originally posted by tcChris@Jan 13 2005, 04:57 PM
what is the factory camber setting on the tC?
According to the FSM it is 0 degrees 31 minutes +/- 45 minutes, caster is 3 degrees 2 minutes with the same tolerance, steering axis inclination (SAI) is 12 degrees 31 minutes, same tolerance.
Toe is most important, and it is 0 degrees +/- 12 minutes, or for us old school types, 0mm +/- 2mm. Toe in tends to cause inner edge wear, toe out tends to cause outer edge wear. There is a huge difference in wear between 2mm toe out and 2mm toe in.
Toe is ALWAYS adjusted last because camber and caster changes can affect toe.
There's a lot more to alignment, but this covers the raw fundamental numbers.
1 - 11 of 11 Posts
