Ok so basically our stock head units are double din. I pulled the trim plate off from around the shifter. then pull up the center piece (making sure to disconnect the wire harness going into the back of it) Now your looking at the stock stereo and two metal brackets on each side. Bottom of the brackets have two screws and the top have two nuts (10mm use a deep socket). After that if you have ever replaced a head unit you should now what else needs to be done.
^^^just for reference if someone didn't already know
So I installed my Pioneer DEH-P7700M, but now I'm having clearance issues with the lid closing. Has anyone else run into this with other aftermarket head units, and if so where you able to fix it?
