Make sure it has oil. I know it sounds silly, but it normally means your dipstick is dry. Remember, if the oil ring service was not done, it will burn a LOT of oil. Mine burns through almost 5 quarts between each 3k mile oil change. Make it a habit of popping that hood every Friday or Monday or whenever, checking oil, water, coolant, break, steering, transmission, anything and everything that can be filled should be filled.
