im saving my vote until i see comparison of the performance benefits of each
i am on the same page here.Originally posted by lo bux racer@Oct 31 2005, 12:54 AM
If NST wants to talk to ATI, Fluidampr, or TCI and incorporate a proper harmonic damper into their solution, then I'm all for it.
~10% is a guesstimate for initial offerings with later offerings increasing (~20% etc.), but that's still preliminary since they are still in the R&D stages for their solid pulley solutions (both crank overdrive and supercharger overdrive). The point made was that both solutions would be designed to yield the same amount of increased supercharger drive rate, so it's up to the customer to decide which way they wanted to go (overdrive everything and risk torque shock/oil pump issues, but preserve supercharger warranty, or screw the supercharger warranty, but do nothing to the rest of the car). That was the figure I was told to provide; I am not allowed to discuss the expected increase in PSI that was mentioned to me by NST, and I don't want to, since those figures are not yet final, either.Originally posted by raamaudio@Nov 1 2005, 11:16 AM
I think they may be way off base on the number of customers that would pay more for a proper crank pulley. With the magantude of real world performance gurus against solid pulleys it should be easy to convince those wanting more power and to keep thier warranties to spend a bit more on what is really a low cost upgrade(as long as the rest of the system can support more boost that is
10%?? Is that an arbitrary number?? I think a few sizes should be made and tested to see what actually can work the best, possibly optional sizes, 2-3 or so would work out.
Sure, the cost to make them is a bit but once the intial design is done making different sizes is not that hard to do.
