Wanna bet? I bet a lot of money all you did was restore stock performance. Grounding kits are USELESS compared to the OEM system. If your grounds are bad because of corrosion, then a grounding kit will restore OEM function, but will not provide any performance increase.
Stronger coils do NOT make more power. They use more electrical power, and if the OEM piece was working, it is extremely unlikely replacing the coil did anything. Besides, idling is the smallest load on your ignition system, and idle only takes about 6kV which even a marginal coil will produce.
Bad wires are bad wires, and all HV wires eventually go bad. Again, there will be NO performance increase from taking a properly functioning set of wires off and putting on aftermarket wires. If your OEM wires are old and leaking HV (as the ALL do after time) then replacing them with ANYTHING will be an improvement.
I've spent WAY too much time developing ignition systems to believe any of this BS about wires, grounding kits, and hot coils. The guys selling this stuff are just out to make a buck.
If you've modified your engine (higher static or dynamic compression ratio) then MAYBE there is some value to this. For a bone stock engine, NO WAY!
