1 - 5 of 5 Posts
I just bought a new Kicker KX-450.2 amp to power my Solo Baric L5. I installed it and put it in, in the place of my old amp but it is not turning on. The power light does not go on at all. I am running 4ga streetwire on it so I'm pretty sure the power is there but I still dont' know why it isn't turning on, my old amp worked fine. If anyone has any input please let me know, i reallly don't want to spend another 100 to have it installed at an audio shop thanks!
and double check ur ground wire to the base of the car...mine did the same thing...had to fix the ground wire a few times...kept coming loose
Ok so i thought it was the ground so I changed it, and wow the amp turned on, however when i started turning up the gain the amp went to "protection." It was nowhere near as loud as it should have been.... what's the problem? It did this about 3 times and then the amp just completley shut off... no green power light. I'm not sure what's going on, I'm thinking its the remote wire. What do you all think?
I took the amp to the audio shop near my house and apparently its a dud amp? They were trying to sell me a Directed Xtreme Amp, but I've never really heard much about directed and audio so if anyone has any opinions? Also, when i got home I installed the amp in the reg mode, and not mono-bridged, and it seems to work ok, but it does cut out once in a while. Is the cooling fan supposed to be on continuously? because it isn't, and I dont hear the fan at all... that might be the problem.
1 - 5 of 5 Posts
