Originally posted by mrc00l88@Nov 20 2005, 09:59 PM
the file is NOT .wma, it is an .mp3 file on an .mp3 cd. NOT a .wma
well you show an icon that shows window media player as the icon.. and the rest are X's so the rest play and are mp3's.. not to state the obvious but... Are you sure that file is an MP3 and not a .WAV file? because if it's still in .WAV form then of course it won't play
Check again, so is it a wav file? Let us know..
If it is, you're going to have to encode it into an MP3 and re-burn the disc..
Another idea.. When you burned the CD did you burn it as an MP3 cd in nero? Instead of picking "Data disc"? I've found that if i burned cd's the MP3 CD option in nero it wouldn't play some mp3's.. so I chose "data disc" and never had a problem (all being .mp3 files)..
As far as CD-RW's.. the tC's HU won't support multisession discs, which means adding to the disc without reburning the entire disc. The disc has to have its session closed to be read on our HU.. So sure you can add to a disc, just erase the CD-RW and burn everything again with the new stuff included..
let us know all this stuff..
