1 - 5 of 5 Posts
Hello I have a 2008 Scion TC with the VVTI engine. The wiring harness going to my mass air flow sensor had been cut and spliced back together. I am having problems with a high idle with a mass air flow code. My air box is also very rigged into place. At the parts store if I get a new mass air flow sensor it does not match the one thats in my car. So does anybody have a 2008 scion TC with the VVTI engine that would be willing to send a pic of their air box and plug for the mass air flow sensor.
2007 Scion TC 2.4L automatic
Hope the pics help?
7091
7092
7093
7094
New to the scion TC. Bought a salvaged/rebuilt 2007 Scion TC 2.4L automatic.
The person we bought it from didn't disclose & let us know about the salvaged/rebuilt title. It's been in a wreck. Damages are on the front end/wheel passenger quarter that extends to some of the frame & door.
We even asked. Was told it was a clear title. Scion was sitting for 3 months, battery acid all over battery & on engine fuse box (no lid). Missing hoses, broken parts, maintenance history unknown.
Installed new front & rear calipers & brakes.
*New Valvoline Zerex Asian engine radiator Antifreeze/coolant. Full flush & refill.
*New Presone Dot 3 synthetic brake fluid. Full flush & refill.
*New Valvoline Max Life full synthetic ATF Dextron VI, Mercon LV, Dex/Merc fluid. Full flush & refill.
*Have new NGK laser iridium spark plugs (IFR6T11/ Stock # 4588) Not yet installed.
*Have new Valvoline Max Life full synthetic ATF Dextron VI, Mercon LV, Dex/Merc fluid. Not yet installed.
*Have new transmission filter. Not yet installed.
*Have new Valvoline Max Life 5W30 full synthetic engine oil. Not yet installed.
*Have new OEM/factory Toyota engine filter (90915-YZZF1). Not yet installed.
Fixing/repairing/refurbishing other parts. Dealing with cut up, missing frayed, broken wires & harnesses.
Hope the pics help.
Anthony
I would've replied sooner. Have been too busy with this Scion TC. Been chipping away at all it's problems (from previous owners) for the past month.
7 days a week, 8 hrs each day.
Discussion Starter #4
Hope the pics help?
View attachment 7091 View attachment 7092 View attachment 7093 View attachment 7094
Hope the pics help.
Anthony
Yes this helps a ton. looks like I have a different air box and mass air flow sensor. makes since for why it always has a mass air flow code and has a high idle.
Thank you
No problem. Glad the pics helped.
On my Scion TC the engine air box hose/pipe goes into the driver front quarter panel & underneath (covered) by the fender well plastic.
Which will suck up any type of water/splashes upwards thrown by the front wheel & being sucked in.
That's why I've seen way too many Sciin TC owners install a CAI/SRi.
As for me, I'm gonna remove the extension that goes into the front quarter panel/fender.
1 - 5 of 5 Posts
