Every site has it's guru's...on the short time I've been on this site I've quickly learned that lo bux racer is one of them on this site. Everytime I see a post from him I read it, because it usually has some good info in it.
This time I have to correct him though
Top Fuelers and Funny Cars don't chirp gears because they don't have any transmissions...clutch pack to drive shaft to differential. Pro Stockers have so much tire and they have gotten the suspension technology down pat. They rarely break the tires loose despite full throttle shifting with Lenco trannies (can be shifted without depressing the clutch - clutch is only used off the line).
Also on slippery street tires a LITTLE tire spin will most likely net you the best 60 foot times, which equal quicker 1/8 or 1/4 ETs. Why? Because reving up into the meat of the power band just causes massive wheel spin and launching at a low enough rpm to not spin the tires usually causes a bog off the line. Now if you have EddieMoneys' 690hp/675lb-ft Corvette, bogging isn't a problem...but drag racing with street tires and an engine like that would be an exercise in futility
The other option is to rev higher and to slip the clutch off the line to control wheel spin...while that may give you the best launch, it's not going to work for long...a clutch change will be in your near future.
