1 - 5 of 5 Posts
I would like to say hello to all of you as this is my first post here.
I'd like to change driving light bulb, before I buy bulbs I have a question.
Is 100W Halogen bulbs compatible with tC both 9005 and 9006?
As I know standard light bulbs are 9005, 60W and 9006, 51W
If I install 100W light bulb, light bulbs will be burned?
Thank you for your reading everybody.
I agree. You might burn up the wiring and you will definately discolor the lenses if not worse. Use replacement bulbs that are of the same wattage OR replace all of you wiring with thicker gauge and drill a few holes in the lense to allow the heat to escape.
Personally, i'd still with the stock setup.
Thank you for your answer. very helpful
1 - 5 of 5 Posts
