1 - 10 of 10 Posts
I heard the intake manifold for the tC is made of plastic? (My friend said he read it in the tC Manual that was out on the internet the .pdf one) If it is plastic, wouldn't that be the first thing you would want to mod?
yep, same as the celica and matrix, the tC runs a high temp plastic intake manifold.
IMO it's not necessarily better to change it out, the plastic is a better thermal insulator (relative to aluminum) that would result in less heating of the intake air on it's way to the combustion chamber. It's also lighter than an equivilant mass-produced (cast) aluminum intake. Just my $0.02
^^^ good thoughts. thanks. thats kinda what i wanted to say, but my brain isnt functioning well this afternoon. oh, and as i am behind on everything, welcome to the site.
most cars use plastic upper-intake plenum's because (as mentioned before) its thermo-conductivity is much higher than that of aluminum. Because of this it sheds heat much faster and can provide some weight savings. There is not a lot of pressure up at the top of intake so its definitley strong enough to handle anything you can throw at it. I know my Mustang had a plastic intake manifold.....even with 420+ HP they would be fine:) - t
Thanks for the welcome!
It's pretty tough for nylon to beat aluminum in thermal conductivity, although there are certain fillers that help, it's still a huge gap. A highly thermal conductive manifold will transfer (exchange) engine & under-hood heat to the intake charge. A quick google search produced an article from the Engineering Design News web site that briefly describes the benefits of the composite intake manifolds. See this PAGE about half way down, the article called "Intake manifold wins SPE Grand Award"
Originally posted by Ivben Blown+Sep 8 2004, 11:47 PM-->QUOTE (Ivben Blown @ Sep 8 2004, 11:47 PM)
<!--QuoteBegin-TCrazy
It's pretty tough for nylon to beat aluminum in thermal conductivity, although there are certain fillers that help, it's still a huge gap. A highly thermal conductive manifold will transfer (exchange) engine & under-hood heat to the intake charge. A quick google search produced an article from the Engineering Design News web site that briefly describes the benefits of the composite intake manifolds. See this PAGE about half way down, the article called "Intake manifold wins SPE Grand Award" [/b]
i knew my wording was off, thanks for sharing that info! - t
from what i can tell, the only thing that could help from a new IM would be: Carbon fiber (for wheght & strength), a larger more free flowing designe, w/ a heat resistent plastic plenem. this should be made in tow types. one for N/A and one for the S/C.
this comes from the fact that the stock IM is fairly efficient already, and is stuck/weged in there in the back behind the engine block. so a canister w/ runners style (like jdm honda preformance styles) wont work, there just isn't the room.
1 - 10 of 10 Posts
