Be sure to clean the areas well with denatured alcohol or mineral spirits prior to application. The most important area for you will be the rear quarters-- those panels are loud. Make sure the ambient temps are between 70º–85º-- colder makes the material tough to work with, hotter makes the material exceeding tough to work with. Lay the material out flat the night before-- that will save some headaches.
how do you get to the rear quarters? i put several layers across the floor of the trunk and on the wheelwells then i took off the back hatch panel and put a few layers under there and it still rattles like a motherf***** in the taillights and such. god that stuff is such a bitch to work with and i was pissed that i spent all that money and time and it didnt do squat. btw cut it up into small squares and it will be a lot easier to work with. oh ya i also misjudged where to put it on the back hatch and now there is dynamat sticking out from under the plastic. be careful!
1 - 5 of 5 Posts
