I have a 2012 Scion tC manual transmission I had to rebuild the transmission, after rebuilding it I put it back into my car after catching one of the transmission bolts the transmission was flush with the engine and I catch the rest of the bolts, but I feel as if the input shaft is not in the clutch disc, because when I put the transmission in gear 5 and rotate the flywheel it rotate easily, but before I put the transmission in the car when I put it in gear and rotate the input shaft I couldn’t even turn it at all. So now am confused as to what could be wrong. The aligned tool it came with fit into the clutch disc as well as the new one so that had me to believe that the disc is the right one I buy but am lost. Any help or suggestions would be much appreciated.
