high precision Housing Unit
28 Views 0 Replies 1 Participant Last post by  ingsites
high precision Housing Unit 1.Product Introduction The Pillow block unit bearing is a bearing unit that combines a rolling bearing with a bearing seat. Most of the spherical bearings are made of a spherical outer diameter, and are installed together with a bearing housing with a spherical inner hole. 2.Product specification Model NumberGG.ASE 20 GGASE20 Shaft Centre Hight (F)115 mm Distance of two bolts (J)308 mm Width (A)95 mm Weight0.47 kg MaterialChrome steel (GCr15) StructurePillow block units HS code8483200000 Precision ratingP0 P6 3.Pillow block units classifications 3.1UC200 series (light series), UC300 series (heavy series), and deformed product UB(SB)200 series. 3.2UK200 series, UK300 series. 3.3With eccentric sleeve: UEL200 series, UEL300 series, SA200 series 4.Product pictures 5.Pillow block units list ModelBasic size(mm)Weight (kg) NumberHdL UCP20130.2121270.7 UCP20536.5251400.8 UCP20747.6351671.6 UCP20954451902.2 UCP21057.2502062.6 UCP21269.8602414.6 UCP21582.6752757.4 UCP22011510038016 UCP30545251751.4 UCP30860402203 UCP31075502755.6 UCP313906534010 UCP3151007538014 UCP3191259047029 UCP32215011052045 UCP32820014062089 6.Production Flow and Quality Control 7.Packing (1) Single white box per bearing, then carton box, plywood pallet. (2) Plastic tubes per 10 or 20 pcs, then carton box, plywood pallet. (3) OEM packing, as buyer鈥檚 requests. 8.Delivery By Air: 3-7 days after on board; By Express: DHL, FedEx, TNT, UPS, Russia direct line, India direct line etc. By sea: 20-35 days to most sea ports in the world. 9.FAQ Q: How long is your delivery time? A: 7-14 days to most countries. We keep plenty of stock for most bearings, can be delivered in 3 days after payment; Please contact to us for large quantity demand. Q: How to place my order? A: You can contact us by pressing 鈥淐hat Now鈥?or start your draft order directly, we鈥檒l check the price and delivery cost, then confirm the order. Q: What鈥檚 the payment term? A: Credit Card (Alibaba on line order), T/T advance, PayPal, Western Union acceptable. Sample orders or order with amount below $3,000.00, 100% in advance For sea shipment, 40% as deposit, 60% on copy of BL. Q: Do you provide samples? Is it free? A: We provide 1-2 samples if the bearing are in stock, but the buyer need to pay the freight chargehigh precision Housing Unit website:http://www.ynr-bearing.com/special-bearing/housing-unit/
1 - 1 of 1 Posts
1 - 1 of 1 Posts
