1 - 4 of 4 Posts
It's normal for AC to have water caused by condensation on auto or home units. What's not normal is leaking at the wrong place (inside car or inside home). Every car have a drain tube to route the water to the outside. Most likely the tube is either blocked, cracked or cut, or disconnected. Need to look where the leak is near the area where the leak is. You may see the tube where it's coming from and fix it with some silicon sealant or reconnect if it came loose. It is a drain tube and have no pressure in the drain tube.
what causes water to leak inside my tc when ac is on
Yes sir is the drian plugged, all you need is a nice air compressor and giving a nice shot. That should fix the problem.
1 - 4 of 4 Posts
