Hey all,
I just installed the Injen CAI and everything was fine except when i went to close my sunroof it wasn't working at first. So i turned off the car and restarted it and the sunroof was working again, then the same thing happened except with the driver's side door and i restarted and it worked. However... the passenger side window only works with the passenger side control, it does not work when the control on the driver's side is used... i restarted the car a couple times and still it does not work. The only thing I can think of is that maybe the ground wire that had to be moved is not in a good enough spot, but I put it where it was supposed to be moved to... I'm thinking there might just be an electrical system restart that I don't know about? The battery had to be taken out so I don't know if there's a specific procedure that has to be done to go back to default. If anyone has any input please post, having to reach over to put the passenger window down sucks. thanks!
