1 - 3 of 3 Posts
hey guys im planning to do my coilover install but im not sure on how to do it on a tc. i did it to other cars but not with a tc. anybody with a DIY coilover install? either that or some help with just how do i remove that plactic thingy with the wipers connected and the rear trunk?
thanks alot guys
-donut
you dont have to remove the plastic by the wipers. just remove the 2 pins and bend the plastic up enough to get at the nuts. In the rear just remove everything out of the trunk (spare and stuff) and then remove the 10mm bolts under the plastic cover of the cargo hooks. You can see 2 bolts for the rear shocks, the front nuts can be reached by pulling the side pannel up a little. Good luck.
1 - 3 of 3 Posts
