1 - 3 of 3 Posts
i need to know how to remove the plate underneath the shifter on an automatic...ya know the part that says P, R, N, D, etc...the entire silver plate...does it just pop out? any helpe would be wonderful thanks...
after you have the outer housing off (all on clips), use a screwdriver to pop out your shift lock tab in the upper left of the console by the shifter. the floor shift assembly is held in by little claws, best manipulated by a flat tip screwdriver. pop the claws loose (2 each side) and the top plate of the assembly (with your gear indicators) will lift right off. just be careful not to scratch anything, and be careful while lift the console off and such as there are wires attached to it you will want to unclip. hope this helps.
1 - 3 of 3 Posts
