Hmm... mine doesn't buzz to remind me. It will automatically turn off the headlights when I open my door. I've done that a few times too.
on my tC.. if i turn off the car and pull the keys out.. then open the door the lights shut off automatically.. i think it will buzz if you leave the keys in and open the door.. try that and see if it buzzzes..Originally posted by Ivben Blown@Aug 25 2004, 03:22 PM
The owners manual says (page 80) that if the headlight switch is turned on (or off then on in the case of an automatic light cutoff) with the driver's door open, a "buzzer will remind you to turn the lights off".
Mine doesn't work and I just wanted to check with other owners to make sure it was a defect before I take it to the dealer.
same for me. mine just shut off automatically. no buzzing involved. i didn't try leaving the key in, but in that case wouldn't the buzzing be to indicate that your keys are still in the ignition and not that the headlights are on?Originally posted by sciontc_mich@Aug 25 2004, 02:03 PM
there wouldn't be a point to buzzing if it turns it off automatically.. try leaving the keys in and opening the door.. let us know![]()
welcome to the board!
So far I've tried every imaginable combination of key/switch/door sequence and haven't heard the buzzer once as a headlight reminder (but the buzzer DOES work as a "key in the ignition" reminder).Originally posted by zoltiz@Aug 25 2004, 02:48 PM
There is a headlight buzzer. As the manual says it will buzz if you turn your headlights after you open driver's door, or do it in any order other than what the manual says is required for the headlight auto-off feature to work.
